  • 1 Vote(s) - 4 Average
Intermittent ‘Stop’ command - FAAC 741 Sliding Gate
I have a 741 that’s been running well for a few years. Recently I’ve found that intermittently it does not respond to an Open Input. Having checked and monitored the Gate Status Code Display, it seems to correlate to it thinking that a Stop input is present. Then at one point I found the display flickering between 2 (Stop) and 0 (Closed) when the gate was at rest Closed.  Yet my Stop input (Terminal 5) has a wire linking it to - (Ground) so should be a hard Normaly Closed input (not stop).
Has anybody experienced this type of situation or have any suggestions ?
Bob
(21-04-2024, 05:57 PM)bwel Wrote: Hi,
Bob
Thank you for your enquiry.
This is definitely a strange fault considering you have the stop command shorted as it should be due to it being a safety input. Have you isolated the board and checked the back of the PCB for any sort of ingress and potentially a short?
Bob
I contacted FAAC Technical and they thought that perhaps the Magnetic Limit switch was not properly sensing the Close Magnet on the Toothed Track. I need to wait for it to fail again and check the FCC LED on the board.
Many thanks,
Bob
Many thanks,
Great.
it would be interesting to know the outcome for our technical literature. Keep us posted.
  Faac 415 can't reset from manual to operate mode Stephen Q 1 1,555 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 2,517 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 3,140 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 7,649 21-11-2022, 09:54 AM
  FAAC gates help - code change from previous owners trekkerglenn 3 5,648 14-11-2022, 12:03 PM
  Gate continues trying to open tjtj6554 1 3,242 20-09-2022, 08:02 AM
  FAAC sensors and Beninca R16E motor Beachcomber 7 10,986 20-07-2022, 09:50 AM
  Faac 455 beginner help please Ghutson70@gmail.com 2 8,655 30-05-2022, 09:12 AM
  Faac C721 trips mains when connecting transformer Gatehelp 3 6,906 24-05-2022, 08:36 AM
  Faac Ufo Rail manual to auto mode TibiHu 1 5,024 07-03-2022, 11:03 AM
