  • 4 Vote(s) - 2 Average
Faac 455d
Hi hoping someone can help me. I tired to change the opening time on my control panel and  messed it up. I have looked at the manual and can seem to get the time to change and open. Trouble is when it open and closes the motor just keeps running. Its like it hasn't recognised that it has reached its stop position. I went onto tl pressed plus and gate opens. Pressed my remote at the  end of opening thought I had done it. When it shuts it doesn't recognise it is actually shut. Spent two hours trying to work out.  Can anyone help please?
It may be worth trying to re-learn the limits for this motor. This is done by closing both leaves, --> enter BASIC PROGRAMMING --> select TIME LEARNING --> Then press the + button for 1 second. As soon as the leaves reach the opening contact point, give an OPEN command from your remote fob or pushbutton. Once you have done this, press push button F to exit and save programming.
However, it could possibly be a simple case of changing the opening time back to how it originally was. To me it looks like this has been changed which is telling the motors to operate for a longer amount of time which would cause the motor to keep running.
Many Thanks.
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 270 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 1,486 18-03-2024, 01:20 PM
Last Post: RXH
  FAAC 740 limited travel LoneStarCycler 0 3,089 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 7,594 21-11-2022, 09:54 AM
  FAAC gates help - code change from previous owners trekkerglenn 3 5,576 14-11-2022, 12:03 PM
  FAAC sensors and Beninca R16E motor Beachcomber 7 10,946 20-07-2022, 09:50 AM
  Faac 455 beginner help please Ghutson70@gmail.com 2 8,622 30-05-2022, 09:12 AM
  Faac C721 trips mains when connecting transformer Gatehelp 3 6,876 24-05-2022, 08:36 AM
  Faac Ufo Rail manual to auto mode TibiHu 1 5,002 07-03-2022, 11:03 AM
  FAAC NOT AUTO CLOSING. BROKEN WIRE Slick19000 3 8,445 04-01-2022, 09:48 AM
