  • 6 Vote(s) - 2.33 Average
FAAC gates help - code change from previous owners
Hi all,
Brand new here!
I've recently moved into a new property with already installed FAAC double gates, they work great BUT the other night I found the previous owner on my driveway (inside the gates) as they were coming to collect some old bits but rather than wait for me to arrive they used the gate code to allow entry
This has freaked me out a little and I now want to change the code on the gates for our new ownership, I a) have no clue how to do this and b) am worried it'll mess with the 'you can ring the gates from your mobile to open them' function too?
I've been told by the PO that there's a sim card inside the gates and this needs topping up for the mobile function to work, usually a £10 top up lasts 2-3 months?? again no idea if this can be brought into this decade as it seems a bit faffy to have to remove a sim and top it up every quarter?
Hopefully someone can offer a noob some help and advice
Glenn
(03-11-2022, 12:55 AM)trekkerglenn Wrote: Hi all,
Brand new here!
Glenn
can solve the last part buy a new sim and you can top it up online no need to remove it. Or find out the old sim supplier and do that online. You can also reset the board back to factory settings it should tell you in the manual how to do this or download one. Just follow the instructions and it should be like a new install or you could use the old code to enter a new one if you got the manual
I had the same problem, and this is how i solved it. you will need to erase all the previous tel numbers from the system any way they will all still have access if it works the same as mine
Hope this helps
Brand new here!
Glenn
Thank you for your enquiry,
Could you verify what dial to open system that you have on your FAAC System, if you were to find out where your GSM dial to open device is located (Usually in a IP rated box) we can hopefully open it up and identify which one you have and advise you accordingly.
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 270 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 1,486 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 2,456 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 3,089 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 7,593 21-11-2022, 09:54 AM
  E145s - error code 5 during setup pete.23 2 9,996 12-08-2022, 08:13 AM
  FAAC sensors and Beninca R16E motor Beachcomber 7 10,945 20-07-2022, 09:50 AM
  Faac 455 beginner help please Ghutson70@gmail.com 2 8,622 30-05-2022, 09:12 AM
  Faac C721 trips mains when connecting transformer Gatehelp 3 6,876 24-05-2022, 08:36 AM
  Faac Ufo Rail manual to auto mode TibiHu 1 5,002 07-03-2022, 11:03 AM
