  • 2 Vote(s) - 3 Average
Faac 415 can't reset from manual to operate mode
Just had to replace large gate post and uninstall then reinstall faac 415.
Getting full electricity through as electro magnetic plate binds very strongly to lock leaf but when gate is activated to open it moves four inches and locks out. The cylinder arm is not retracting and prevents further movement then the system seems to lock out and I have to turn off and repower to reset but it repeats process.
I think the manual override is the problem as I can't reset out of manual. The release system just spins rather than going back to operational.
Hope that makes sense.
Does anyone have any similar experience?
Thank you in advance. Smile
(08-01-2024, 11:43 PM)Stephen Q Wrote: Just had to replace large gate post and uninstall then reinstall faac 415.
Hi Stephen Q, were you able to solve this issue? I'm having the same problem. I had to manually override the opener due to power outage and now it will not re-engage. Any tips would be greatly appreciated.
Thank you!
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 235 22-04-2024, 03:21 PM
  Faac 455d Grantplant 1 2,445 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 3,075 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 7,582 21-11-2022, 09:54 AM
  FAAC gates help - code change from previous owners trekkerglenn 3 5,557 14-11-2022, 12:03 PM
  FAAC sensors and Beninca R16E motor Beachcomber 7 10,941 20-07-2022, 09:50 AM
  Faac 455 beginner help please Ghutson70@gmail.com 2 8,616 30-05-2022, 09:12 AM
  Faac C721 trips mains when connecting transformer Gatehelp 3 6,873 24-05-2022, 08:36 AM
  Faac Ufo Rail manual to auto mode TibiHu 1 4,999 07-03-2022, 11:03 AM
  FAAC NOT AUTO CLOSING. BROKEN WIRE Slick19000 3 8,442 04-01-2022, 09:48 AM
