  • 8 Vote(s) - 2.88 Average
Faac 455 beginner help please
I have recently brought a property in France which has an FAAC 455 gate system installed which isn’t working and I am trying to trouble what the issue might be.  I have power to the board and have the tree lines displayed. I have 240V to the main input contacts but no power to the gates or on the contacts for the gates 1 to 6.
I have no manual so don’t know how to manually set the gates to open to see if the gates even function.
Can anyone advise what I can set on the Board to manually control the gates so I can at least see if the gates function once power is delivered?
Both fuses on the board seem OK and I have voltage to the receiver board but the remote supplied does nothing.
Thanks in advance.
G
hi. update to this. I have found how jumper across 9 and 14 to manually open the gates and the gates work which points it towards being the receiver or remote controls. The plug in module for the receiver doesn’t seem to do anything when I press the learning button so I’m wondering if it is this that is non functional. If anyone has any ideas of how I could troubleshoot this further to narrow down the issue more I would be very greatful. thanks
(29-05-2022, 01:47 PM)Ghutson70@gmail.com Wrote: hi. update to this. I have found how jumper across 9 and 14 to manually open the gates and the gates work which points it towards being the receiver or remote controls.  The plug in module for the receiver doesn’t seem to do anything when I press the learning button so I’m wondering if it is this that is non functional.  If anyone has any ideas of how I could troubleshoot this further to narrow down the issue more I would be very greatful. thanks
Thank you for your question.
Please see manual as below.
https://manuals.easygates.co.uk/PDF/misc/455-D.pdf
What i would do is take out all of the cabling and just leave the motors in. then i would recommend doing a position search (into basic learning then initiate time learning.) once the gate is fully operational i would reintroduce each input such as photocells and command inputs one by one just to make sure there are no faults on those circuits.
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 261 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 1,482 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 2,453 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 3,085 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 7,591 21-11-2022, 09:54 AM
  FAAC gates help - code change from previous owners trekkerglenn 3 5,570 14-11-2022, 12:03 PM
  FAAC sensors and Beninca R16E motor Beachcomber 7 10,945 20-07-2022, 09:50 AM
  Faac C721 trips mains when connecting transformer Gatehelp 3 6,876 24-05-2022, 08:36 AM
  Faac Ufo Rail manual to auto mode TibiHu 1 5,001 07-03-2022, 11:03 AM
  FAAC NOT AUTO CLOSING. BROKEN WIRE Slick19000 3 8,444 04-01-2022, 09:48 AM
