  • 2 Vote(s) - 4.5 Average
Gate continues trying to open
Hello All--
New faac 402 with 455 d control board:  Gate continues trying to open more after stopping and reaching approximately 90 degrees.
For about 20 seconds it will make loud humming sound, like it is trying to open.  After the 20 seconds it will go into the pause mode and subsequently close. Why is the arm doing this?  The 455 d manual does not seem to address.  Appreciate any assistance.
Thank you,
Kevin
(04-09-2022, 05:59 PM)tjtj6554 Wrote: Hello All--
Thank you,
Kevin
Good Morning,
It sounds like the board hasn't learnt its limits or lost its memory and is over running. If you go into the first level of parameters and select time learning this will relearn the limits.
Page 17 section 5.1 for reference.
https://manuals.easygates.co.uk/PDF/misc/455-D.pdf
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 269 22-04-2024, 03:21 PM
  Latch open with Videx GSM DP86 3 3,598 20-09-2022, 08:06 AM
  Faac gate opens when photo cell beam is broken Stephen Q 5 12,124 29-03-2021, 01:53 PM
Last Post: Stephen Q
  Fine tuning gate stopping point jwcgc629 0 4,622 11-12-2020, 04:53 PM
Last Post: jwcgc629
  FAAC Gate Issue asifrana 0 7,200 26-07-2020, 10:53 PM
Last Post: asifrana
  Gates open /won't close mag1173 0 7,751 09-07-2016, 03:46 PM
Last Post: mag1173
  Trouble keeping gate closed tkalfaoglu 0 7,755 28-06-2016, 10:02 AM
Last Post: tkalfaoglu
  415 24V Forced open by rolling car mpit 1 11,699 01-09-2014, 08:10 AM
Last Post: thm
  Difficulty installing Faac gate opener grigadale 1 14,091 31-07-2012, 04:17 PM
Last Post: acsys
Question Do I need to use the same manufacturer to replace my gate remote control? danemo 1 13,502 31-03-2011, 12:45 PM
