  • 4 Vote(s) - 3.5 Average
Faac 455d Control Panel with XF868 Receiver
Hi I am installing an xf868 receiver to my 455d control panel but I am wondering is this quick connect as cables come loose when I connect up to power supply manually when pushed in. The receiver is 3 connectors but panel at quick connect is 5, ant help here would be great.
(29-10-2021, 02:20 PM)Dec Wrote: Hi I am installing an xf868 receiver to my 455d control panel but I am wondering is this quick connect as cables come loose when I connect up to power supply manually when pushed in. The receiver is 3 connectors but panel at quick connect is 5, ant help here would be great.
Hi I contacted the seller and I have been informed I got the wrong part by mistake so awaiting replacement. Hopefully this resolves the issue.
(30-10-2021, 07:50 PM)Decyep wrong type, need the other plug on board, that is is used on 24v boards Wrote:
Hi Dec,
Power will be wired into the receiver. You will then need to wire from the relay outputs to the push button/open input on the 455d panel. When the receiver is triggered, it will trigger the input, opening the gates.
-Jamie
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 328 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 1,541 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 2,504 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 3,128 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 7,636 21-11-2022, 09:54 AM
  FAAC gates help - code change from previous owners trekkerglenn 3 5,624 14-11-2022, 12:03 PM
  FAAC sensors and Beninca R16E motor Beachcomber 7 10,969 20-07-2022, 09:50 AM
  Faac 455 beginner help please Ghutson70@gmail.com 2 8,647 30-05-2022, 09:12 AM
  Faac C721 trips mains when connecting transformer Gatehelp 3 6,894 24-05-2022, 08:36 AM
  Faac Ufo Rail manual to auto mode TibiHu 1 5,014 07-03-2022, 11:03 AM
