  • 5 Vote(s) - 2.8 Average
FAAC 455d electrical interference
I just had my control panel and actuators replaced on an existing gate. When my yard care person uses a gas powered blower on driveway at the gate, the control board gets into a problem state.
So this situation happens when the gate is held open by a toggle switch (the inside manual opener) and he uses his blower. He doesn't touch the actual gate. Upon flipping the toggle switch to close the gate, then after time delay, one of the two sides of the gate doesn't close. It sounds like the actuator for that misbehaving gate side is working, but nothing moves; maybe actuator turning in wrong direction.
The "remedy" is to open the black cover on actuator, rotate red valve to manual operation, manually close the misbehaving gate, putting red valve back into operating position, and then  gate operates fine for a week until the yard care person uses his blower again.
Looks like electrical including equipment ground is properly connected.
I am guessing electrical interference gets control panel into unexpected logic state.
I suppose I could put toroids on all the low voltage wires entering control panel (except sense loop).
Has anyone run into this? Anyone have any insight?     (( besides buying him a Li  battery blower))
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 344 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 1,550 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 2,513 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 3,136 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 7,645 21-11-2022, 09:54 AM
  FAAC gates help - code change from previous owners trekkerglenn 3 5,640 14-11-2022, 12:03 PM
  FAAC sensors and Beninca R16E motor Beachcomber 7 10,986 20-07-2022, 09:50 AM
  Faac 455 beginner help please Ghutson70@gmail.com 2 8,653 30-05-2022, 09:12 AM
  Faac C721 trips mains when connecting transformer Gatehelp 3 6,905 24-05-2022, 08:36 AM
  Faac Ufo Rail manual to auto mode TibiHu 1 5,023 07-03-2022, 11:03 AM
