  • 8 Vote(s) - 2.63 Average
Faac E145s help please
When I power up my cb the display shows the following:
"bo" with two blue led's for 5 seconds.
It then changes to blank screen with two blue led's and one red.
Nothing else appears at all.
Can anyone advise on this? Is it possible to do a reset?
Could the board not have any software on it and do you know if it's possible to have faac look at this? It's a new system which I have just installed and can't figure it out.
Thank you for your help.
(23-08-2020, 08:51 AM)pm9020 Wrote: Hello,
I have exactly the same problem. Got the board replaced but it’s doing exactly the same thing. bo and 2 blues and red error light.
Did you get a solution?
There must be a way to reset the software?
One of the topics is not getting loaded in the help file;
It shows: 404: File or Directory not found error?
Is there anything i can do to check whats wrong?
regards,
Raghu
you need to wire the connectors first, it cant see any safetys etc.
then you can go through programming using the 'f' key
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 328 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 1,540 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 2,504 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 3,128 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 7,635 21-11-2022, 09:54 AM
  FAAC gates help - code change from previous owners trekkerglenn 3 5,622 14-11-2022, 12:03 PM
  E145s - error code 5 during setup pete.23 2 10,011 12-08-2022, 08:13 AM
  FAAC sensors and Beninca R16E motor Beachcomber 7 10,969 20-07-2022, 09:50 AM
  Faac 455 beginner help please Ghutson70@gmail.com 2 8,646 30-05-2022, 09:12 AM
  Faac C721 trips mains when connecting transformer Gatehelp 3 6,894 24-05-2022, 08:36 AM
