  • 24 Vote(s) - 4.46 Average
FAAC 455D won't operate
Hi All,
I have just fitted a FAAC 415L being controlled by a 455D control unit.  The control unit is using a RP 868 SLH.  I have no safety devices connected to the system. When power (240v) is applied I get the LED FSWOP and FSWCL lit (which is what I expected as I have jumper leads between pin 19 and 12 / 13; as per wiring diagram Fig 7 in manual).
I have run through the TL Complete Learning process and the gate operates perfectly during the learning cycle open-stop-close sequence.  I press button F to save / exit the learning mode.
However I get no reaction to pressing the remote control when not in learning mode? The receiver LED flashes when I press the button and I get the Op_A LED flashing when I press the button? I do not get the stop LED flashing at any point.
I have done some experimenting and if I jumper pins 14 to 11 (STP) then the gate will open and stop as per expected. However, when the gate is closing pressing the remote control button to stop the gate goes straight into open? Also when opening the gate does not remember the TL 'complete' sequence?
Have I missed jumper lead during the installation or am I doing something wrong on the setup sequence.
Any guidance would be appreciated
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 347 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 1,553 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 2,515 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 3,138 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 7,647 21-11-2022, 09:54 AM
  FAAC gates help - code change from previous owners trekkerglenn 3 5,644 14-11-2022, 12:03 PM
  FAAC sensors and Beninca R16E motor Beachcomber 7 10,986 20-07-2022, 09:50 AM
  Faac 455 beginner help please Ghutson70@gmail.com 2 8,654 30-05-2022, 09:12 AM
  Faac C721 trips mains when connecting transformer Gatehelp 3 6,906 24-05-2022, 08:36 AM
  Faac Ufo Rail manual to auto mode TibiHu 1 5,023 07-03-2022, 11:03 AM
