  • 7 Vote(s) - 2 Average
FAAC 455D programming
Hi all hoping someone would be able to help. My friend got decided to make his gates electric so got somebody to come and do it for him. The guy that started the job left my mate in the lurch and is avoiding his calls. He asked if I’d be able to do them as I’m an electrician, I told him I’ve never had anything to do with gates but agreed to help. I’ve got the 455d circuit board controlling 2 swing gates, with remote to open them. When pairing the remote was done we then went onto learning the gates which all went ok but when that was finished nothing happens with the gates when pressing the remote! Was wondering if anyone could help as contacted facc technical and had no luck from them. Thanks in advance
(19-06-2020, 11:02 PM)Harrisbhreac Wrote: Hi all hoping someone would be able to help. My friend got decided to make his gates electric so got somebody to come and do it for him. The guy that started the job left my mate in the lurch and is avoiding his calls. He asked if I’d be able to do them as I’m an electrician, I told him I’ve never had anything to do with gates but agreed to help. I’ve got the 455d circuit board controlling 2 swing gates, with remote to open them. When pairing the remote was done we then went onto learning the gates which all went ok but when that was finished nothing happens with the gates when pressing the remote! Was wondering if anyone could help as contacted facc technical and had no luck from them. Thanks in advance
Hi, I had a similar problem (still have an issue), if you use a jumper lead between pins 11 and 14 does the gate operate? I also have jumper leads between pin 19 and 12 & 13 (see fig 7 in the installation manual). My issue now is that its not following the TL Complete sequence that I programmed (TL programme works perfectly).
Hope this helps
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 329 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 1,543 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 2,506 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 3,130 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 7,638 21-11-2022, 09:54 AM
  FAAC gates help - code change from previous owners trekkerglenn 3 5,626 14-11-2022, 12:03 PM
  FAAC sensors and Beninca R16E motor Beachcomber 7 10,969 20-07-2022, 09:50 AM
  Faac 455 beginner help please Ghutson70@gmail.com 2 8,647 30-05-2022, 09:12 AM
  Faac C721 trips mains when connecting transformer Gatehelp 3 6,895 24-05-2022, 08:36 AM
  Faac Ufo Rail manual to auto mode TibiHu 1 5,014 07-03-2022, 11:03 AM
