  • 17 Vote(s) - 2.94 Average
Faac s800h
Hello I have a Faac double s800h swing gate . I’ve done the encoder update and installed a new control board plus faac photocells. I’ve opened the gates half way and placed system into its manually learning mode. Gate runs through the motions, once learning has completed it clicks out of the set up mode and the gate waits out the pause time and shuts. Now when I’m attempting to use the remote to open the gate, it clicks on the receiver and the control board open led lights up but gate does not open or even move at all. I’m not sure if I’m missing something or some  how my wiring isn’t correct. But Board doesn’t throw any errors and led system lights all show it’s good. I’m lost at this point and any help would be greatly appreciated.
Are you using 24 volt system or 240
What panel face e145 or e124
If it’s the latest version then you don’t do a set up from halfway
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 348 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 1,555 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 2,517 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 3,140 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 7,649 21-11-2022, 09:54 AM
  FAAC gates help - code change from previous owners trekkerglenn 3 5,647 14-11-2022, 12:03 PM
  FAAC sensors and Beninca R16E motor Beachcomber 7 10,986 20-07-2022, 09:50 AM
  Faac 455 beginner help please Ghutson70@gmail.com 2 8,654 30-05-2022, 09:12 AM
  Faac C721 trips mains when connecting transformer Gatehelp 3 6,906 24-05-2022, 08:36 AM
  Faac Ufo Rail manual to auto mode TibiHu 1 5,023 07-03-2022, 11:03 AM
