  • 94 Vote(s) - 2.89 Average
Faac 640 query
I moved my query from the introduction section, see is there any more action in the Faac section.  Big Grin
I  recently stripped down an old Faac 640 automatic barrier, rebuilt it including a brand new piston and a new spring for a 7 metre beam.
Electrically it works perfectly but it groans and is very noisy. When closing I have to assist it, by leaning on it.
Note: As it's inside my garage, I only have a 2 metre plank instead of a 7 metre beam installed.
Used genuine Faac oil and level on dipstick is OK.
Bled pistons for air a number of times, spring side when opening, non spring side when closing. (made no difference)
When I put pump in manual operation, the motor runs quietly, and the barrier rises quietly by hand.
My question is when closing against the 7 metre spring does the barrier need the assistance of the 7 metre beam or should the pump overcome the resistance regardless.
Why is it noisy and groaning, I don't recall it being so, when it was last used (long time ago). Is the pump ill ?
Thanks.
This forum has the quietest 1740 members on the internet.
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 347 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 1,553 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 2,515 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 3,138 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 7,647 21-11-2022, 09:54 AM
  FAAC gates help - code change from previous owners trekkerglenn 3 5,644 14-11-2022, 12:03 PM
  FAAC sensors and Beninca R16E motor Beachcomber 7 10,986 20-07-2022, 09:50 AM
  Faac 455 beginner help please Ghutson70@gmail.com 2 8,654 30-05-2022, 09:12 AM
  Faac C721 trips mains when connecting transformer Gatehelp 3 6,906 24-05-2022, 08:36 AM
  Faac Ufo Rail manual to auto mode TibiHu 1 5,023 07-03-2022, 11:03 AM
