  • 307 Vote(s) - 2.98 Average
BFT Sub first gate slow to open
Hi: I have a sub gate opening system on my gates . The model includes slowdown & hydraulic lock.
The gate have been installed for about 10 years with normal domestic use.
My problem is that the first gate is slow to start opening and starts to move just before the second gate starts to open .
The hydraulic pump activates immediately, but it seems to have to build up the pressure before the gate starts to open.
I initially thought that is was lack of oil, but it only needed a small amount to top up. Topping up the oil made did not have any effect on the fault.
The second gate works perfectly - pump starts and gate starts to open immediately.
This gate is slow to react on both the opening and closing sequence
I suspect that some sort of internal seal is faulty and I would be grateful for any advice .
A few easy checks will sort out the problem for you,
Can you see any oil leak? if so you will need to purchase a oil seal kit and fit it, messy and time consuming
if not any leaks;
Manual release the unit
slowly push the gate to the open position
unscrew the filler cap on the unit
there should be visible oil near the top (the oil goes down when the gate is closed)
top up if needed
reassemble the unit
run the gate a few times to bleed any air out of the system
all should be ok now
  BFT Sliding Gate randomly opening and closing AdrianMate 2 1,251 Yesterday, 10:30 AM
Last Post: Adamit
  Gate wont close issue MR_ROBOT 3 10,116 11-04-2024, 08:08 AM
  Bft gate problem djkokalis 1 1,573 14-02-2024, 12:39 PM
  Ecosol/Kustos doesn't open and close fully? supremee 3 2,682 09-02-2024, 03:12 PM
Last Post: EdwardBab
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,412 04-01-2024, 10:21 AM
  BFT sliding gate intermittent operation vozm100 5 2,496 02-10-2023, 09:08 AM
  BFT LUX2B Intermittent failure to open brookkr 4 8,198 07-09-2023, 08:32 AM
  BFT Thalia ‘Hold Open’ hehasmoments 5 4,518 24-08-2023, 01:38 PM
  Set remote to “only open” gate mark123499 4 4,122 30-05-2023, 01:57 PM
Last Post: mark123499
  Parallel (or not) gate motors Ian Evans 1 2,553 16-05-2022, 11:44 AM
