  • 15 Vote(s) - 2.67 Average
Gate wont close issue
Hi all, I have had a good read of a lot of threads on here and can’t see the to find my exact issue.
I have a sliding electric gate (BFT Deimos Ultra BT A 600) and after opening it this morning it now wont close.
The LCD on the PCB displays Phcl  which from looking at manual is PHOT CL closing photocell input activated.
It is raining outside and I’m wondering if this has caused the issue with ingress causing a problem with one of the photocells.
I am a bit new to the diagnostics of these issues so any help would be appreciated.
There are two sensors on the sliding gate which align when open/close with a sensor on the ground unit.
There are two static photocell sensors on either wall of the gate entry which I’m assuming is the safety beam aspect.
Is the Phcl error to do with the ones on the wall?
Hope you can help.
Turns out I solved this myself in the end.
It was the battery in the photocell TX/RX module on the wall. Just needed a new 3V battery (size C2).
Figured I’d leave the post here just incase it helps anyone else with similar situation.
Apologies if basic user error for most people.
(04-07-2020, 01:10 PM)MR_ROBOT Wrote: Turns out I solved this myself in the end.
hi Mr Robot... i think i have the same issue. I can't work out exactly where the battery is...
benj
benj
if you have battery photocells they will be on the RX side of the photocell set. you may have a hard wired system which would mean you do not have a battery photocell.
  Bft gate problem djkokalis 1 1,305 14-02-2024, 12:39 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 1 987 14-02-2024, 12:18 PM
  Ecosol/Kustos doesn't open and close fully? supremee 3 2,411 09-02-2024, 03:12 PM
Last Post: EdwardBab
  Thalia - Photocell Close J to the D 1 843 19-01-2024, 09:54 AM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,190 04-01-2024, 10:21 AM
  BFT sliding gate intermittent operation vozm100 5 2,227 02-10-2023, 09:08 AM
  Set remote to “only open” gate mark123499 4 3,879 30-05-2023, 01:57 PM
Last Post: mark123499
  Parallel (or not) gate motors Ian Evans 1 2,484 16-05-2022, 11:44 AM
  RCD trip on close LUX 2B DP86 3 6,701 14-04-2022, 08:55 AM
  BFT Thalia GSM gate opener SunnyB1 1 3,033 07-03-2022, 10:58 AM
