  • 2 Vote(s) - 1 Average
BFT sliding gate intermittent operation
Hi all,
I wonder if someone can offer some advice, I have BFT motorised sliding gate and occasionally it will not slide across all the way to open and gets stuck.  I have to press the remote again to slide it back etc
We do have a gravel drive and I have made sure the track is clear of debris, my gut feeling is that the sensors are causing the gate to stop and not debris on the track but i am not 100% sure.
I have wiped the black sensors on the gate posts but that didnt seem to have any effect.
I've only had the setup around a year and i am pretty sure its out of warranty.
thanks in advance
steve
Hi Steve,
Have you tried increasing the force of the motor?
Easygates Ltd
(25-09-2023, 11:03 AM)Michael Wrote: Hi Steve,
Easygates Ltd
Hi Michael,
Thanks for your reply, that might work.
How would I go about doing that?
thanks
steve
Its a BFT Ultra by the way.
Turn out I got a "Safe Edge" sensor, and likley the batteries are low and causing issues with gate.
I've changed the batteries so will see if that reduces the intermittency of the issue!
Let me know the outcome.
Regards.
Easygates
  Gate wont close issue MR_ROBOT 3 9,764 11-04-2024, 08:08 AM
  Bft gate problem djkokalis 1 1,301 14-02-2024, 12:39 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 1 983 14-02-2024, 12:18 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,188 04-01-2024, 10:21 AM
  BFT LUX2B Intermittent failure to open brookkr 4 8,085 07-09-2023, 08:32 AM
  Set remote to “only open” gate mark123499 4 3,876 30-05-2023, 01:57 PM
Last Post: mark123499
  Parallel (or not) gate motors Ian Evans 1 2,484 16-05-2022, 11:44 AM
  BFT Thalia GSM gate opener SunnyB1 1 3,033 07-03-2022, 10:58 AM
  BFT gate won't stop mid way redgraysie 0 3,113 10-12-2020, 12:56 PM
Last Post: redgraysie
  Gate won't close on manual or auto Baz1981 0 5,937 23-06-2020, 05:27 PM
Last Post: Baz1981
