  • 219 Vote(s) - 2.91 Average
BFT LUX2B Intermittent failure to open
One motor occasionally fails to actuate even though the motor can be heard running. Opening the release valve, opening the gate and closing the valve allows it to operate for a few days until it happens again. Have had motor oil refilled / topped up by specialist.
I saw this problem reported before but apparently no solution found. Any clues anyone? Thanks.
(22-03-2015, 10:25 PM)brookkr Wrote: One motor occasionally fails to actuate even though the motor can be heard running. Opening the release valve, opening the gate and closing the valve allows it to operate for a few days until it happens again. Have had motor oil refilled / topped up by specialist.
I have the exact problem pulling my hair out  Re filled with fluid all ok then one stops  it happens when Sad im not there so have not been able to check voltage yet  and will also try bleeding again also going to swap motors over to see if i can confirm details   iv changed capacitors too   its a BFT  LUX 2B 240v
Thanks for the message,
it is hard to definitely say however, it could be a sign of a failing capacitor if it is the 230v variant of the Lux motor. Have you tried replacing this?
Thank you Joe. Yes they are the 240 v version and I have changed capacitors and topped up oil and still no change. Still need help. !!!
(02-09-2023, 08:52 AM)john kennedy Wrote: Thank you Joe.  Yes they are the 240 v version and I have changed capacitors and topped up oil and still no change.  Still need help. !!!
Thank you for your response on this.
Have you tried going through a limit search procedure, I am unaware of what control board you have in situ but every control board has a limit search procedure. Furthermore, if we can identify what control board you have in situ if it has a LCD display on it there could potentially be a fault code on it, could you tell me if this has any message on it?
  Ecosol/Kustos doesn't open and close fully? supremee 3 2,431 09-02-2024, 03:12 PM
Last Post: EdwardBab
  BFT sliding gate intermittent operation vozm100 5 2,247 02-10-2023, 09:08 AM
  BFT Thalia ‘Hold Open’ hehasmoments 5 4,352 24-08-2023, 01:38 PM
  Set remote to “only open” gate mark123499 4 3,897 30-05-2023, 01:57 PM
Last Post: mark123499
  BFT controlled gates open but don't close MikeJep 5 19,861 04-01-2022, 09:58 AM
  Phobos N L BT one leaf won’t open BigJC 0 3,100 11-06-2021, 01:33 PM
Last Post: BigJC
  Rigel 6 - doors do not stay open Poweroftaxi 1 9,259 13-04-2021, 02:41 PM
  BFT Gate won't open or close Steveturbocal 0 8,626 17-11-2019, 11:10 AM
Last Post: Steveturbocal
  BFT wooden gates won’t open Dreddy88 0 6,387 10-08-2018, 07:46 PM
Last Post: Dreddy88
  How to periodically keep gates open ?? !! thomasario 6 40,338 13-03-2018, 04:35 PM
Last Post: thomasario
