  • 4 Vote(s) - 3 Average
Ecosol/Kustos doesn't open and close fully?
I am in Australia and I know Ecosol solar is not common in UK.
I am still giving a try if someone here can help with this.
I am running Ecosol/Kustos set-up.
I finished setting with a jumper on for constant power and it works fine with the jumper on.
However, without jumper it opens and closes only 1/3 of full operation.
What may cause this?
(09-03-2022, 11:51 AM)supremee Wrote: Hi,
Hi ,
I am facing the same issue. Did you find the soltuion?
Have got the solution to it. In logic you will have Aux 0/1/2/3 - make sure the value is 6-gate running ( output active while motors are powered)
Happy to observe this! Awesome ideas and the standard of fine detail distributed is incredible!
Thanks and good day!
  Gate wont close issue MR_ROBOT 3 9,800 11-04-2024, 08:08 AM
  Thalia - Photocell Close J to the D 1 859 19-01-2024, 09:54 AM
  BFT LUX2B Intermittent failure to open brookkr 4 8,087 07-09-2023, 08:32 AM
  BFT Thalia ‘Hold Open’ hehasmoments 5 4,356 24-08-2023, 01:38 PM
  Set remote to “only open” gate mark123499 4 3,899 30-05-2023, 01:57 PM
Last Post: mark123499
  Gates not fully closing stefen1978@hotmail.co.uk 2 2,774 10-10-2022, 10:07 AM
  RCD trip on close LUX 2B DP86 3 6,711 14-04-2022, 08:55 AM
  BFT controlled gates open but don't close MikeJep 5 19,868 04-01-2022, 09:58 AM
  Remote only working close up Uphill 0 2,651 03-10-2021, 07:50 PM
Last Post: Uphill
  Phobos N L BT one leaf won’t open BigJC 0 3,102 11-06-2021, 01:33 PM
Last Post: BigJC
