  • 3 Vote(s) - 2.67 Average
BFT Rigel 4 - single Gate Not Closing
Hi, I have a single gate that is using an old BFT Rigel4 control board which is currently permanently open. I’ve managed to narrow down (or at least overcome) the issue by disconnecting the external manual (push to make) switch, thus the gate now opens and closes via the remote fobs, albeit the sensors if interrupted use to trigger re-opening if an obstruction was detected, currently (with switch disconnected) the gate simply stops immediately. I’ve tested the manual switch and that appears to be fine although I haven’t checked the cable for a short.
Before I call out an engineer, does anyone have any further ideas to isolate the issue please?
Thanks in advance.
(03-01-2024, 12:19 PM)Tsnash Wrote: Hi, I have a single gate that is using an old BFT Rigel4 control board which is currently permanently open. I’ve managed to narrow down (or at least overcome) the issue by disconnecting the external manual (push to make) switch, thus the gate now opens and closes via the remote fobs, albeit the sensors if interrupted use to trigger re-opening if an obstruction was detected, currently (with switch disconnected) the gate simply stops immediately. I’ve tested the manual switch and that appears to be fine although I haven’t checked the cable for a short.
Thanks in advance.
Think you are correct, sounds like a short circuit on the NO/COM connections for the impulse commands.
  Gate wont close issue MR_ROBOT 3 9,786 11-04-2024, 08:08 AM
  Bft gate problem djkokalis 1 1,317 14-02-2024, 12:39 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 1 997 14-02-2024, 12:18 PM
  BFT sliding gate intermittent operation vozm100 5 2,235 02-10-2023, 09:08 AM
  Rigel 6 conections Muttlymoo1979 0 1,315 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Set remote to “only open” gate mark123499 4 3,888 30-05-2023, 01:57 PM
Last Post: mark123499
Exclamation BfT Sub R - No Closing pressure 1 Leaf Bushpig 2 3,224 23-05-2023, 03:48 AM
Last Post: Bushpig
  BFT SubR not opening/closing sometimes Jimmyboy4 3 3,018 09-01-2023, 10:29 AM
  Er 10 code on RIGEL 6 control unit Eddiew 1 2,671 05-01-2023, 11:53 AM
  BFT Rigel 6 - Buttons suddenly stop working RobE 5 4,826 10-10-2022, 01:10 PM
