  • 6 Vote(s) - 2.33 Average
FAAC gates help - code change from previous owners
can solve the last part buy a new sim and you can top it up online no need to remove it. Or find out the old sim supplier and do that online. You can also reset the board back to factory settings it should tell you in the manual how to do this or download one. Just follow the instructions and it should be like a new install or you could use the old code to enter a new one if you got the manual
I had the same problem, and this is how i solved it. you will need to erase all the previous tel numbers from the system any way they will all still have access if it works the same as mine
Hope this helps
RE: FAAC gates help - code change from previous owners - by Ranch2 - 03-11-2022, 06:37 PM
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 630 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 1,785 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 2,718 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 3,311 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 7,848 21-11-2022, 09:54 AM
  E145s - error code 5 during setup pete.23 2 10,098 12-08-2022, 08:13 AM
  FAAC sensors and Beninca R16E motor Beachcomber 7 11,121 20-07-2022, 09:50 AM
  Faac 455 beginner help please Ghutson70@gmail.com 2 8,743 30-05-2022, 09:12 AM
  Faac C721 trips mains when connecting transformer Gatehelp 3 6,984 24-05-2022, 08:36 AM
  Faac Ufo Rail manual to auto mode TibiHu 1 5,074 07-03-2022, 11:03 AM
