  • 191 Vote(s) - 2.9 Average
BFT Deimos gate won't close
#11
Hi Arthur,
I can't see that the fault can be anything else that a faulty set of photocells.
For the cost, is replace them.
Have you had a look online for a replacement set? Could always buy them, try them out (keep the packaging etc and in good condition, if it doesn't work, send the product back for a refund?
PAJ
(07-05-2017, 11:00 PM)MrDiagnostics Wrote: Hi Arthur,
Hi PAJ,
Thanks for your advice. I'm going to buy a new set of photocells.
I've been looking online for a replacement set of photocells which I can only found of their Input Voltage: 12V - 24V AC/DC.
But my current set of photocells which have Input Voltage: 10V - 30V AC/DC.
Could you please tell me if the photocells have Input Voltage: 12V - 24V AC/DC, would that be also suitable for BFT gate?
Thanks,
Arthur
Hi Arthur,
24Vdc/vac photocells will be find, BFT do a few different ones.
Have a look at the ones easy gates sell, you can always give there says team a quick call and they can tell you the product code/price of the ones you need mate.
Cheers
PAJ
(08-05-2017, 05:09 PM)MrDiagnostics Wrote: Hi Arthur,
Cheers
Hi PAJ,
I've finally received a new set of photocells and I've connected them to the gate motor yesterday.
But now the LED display on the control board is off. The LED display was working before I've installed a new set of photocells.
I've checked the main fuse and power connection with a multimeter that they're all OK.
Any suggestions on how to fix this LED fault?
Thanks,
Arthur
Which photocells did you buy and what board are you installing them to?
Access Control Ltd
0800 5677032
www.accesscontrollimited.co.uk
info@accesscontrollimited.co.uk
(02-07-2017, 01:59 PM)Access-Control-Ltd Wrote: Which photocells did you buy and what board are you installing them to?
Hi Access-Control,
Thanks for your response.
I've bought a set of LP Security Photocells, Model: P5001 with 12m range powered from 24vac/dc.
I've installed them to BFT Deimos BT automatic gate.
Any suggestions on how to fix the LED fault?
Thanks,
Arthur
  Question BFT Deimos A400 Makaroni 1 102 11 hours ago
Last Post: KennethPew
  BFT Sliding Gate randomly opening and closing AdrianMate 2 1,276 17-05-2024, 10:30 AM
Last Post: Adamit
  Gate wont close issue MR_ROBOT 3 10,123 11-04-2024, 08:08 AM
  BFT Deimos BT A600 fault Error 10 Airbus330/300 5 6,972 06-03-2024, 11:59 AM
Last Post: GateOpe
  BFT deimos smoke from board stanli200188 1 1,170 05-03-2024, 04:17 PM
  Bft gate problem djkokalis 1 1,585 14-02-2024, 12:39 PM
  Ecosol/Kustos doesn't open and close fully? supremee 3 2,696 09-02-2024, 03:12 PM
Last Post: EdwardBab
  Thalia - Photocell Close J to the D 1 1,067 19-01-2024, 09:54 AM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,416 04-01-2024, 10:21 AM
  BFT sliding gate intermittent operation vozm100 5 2,501 02-10-2023, 09:08 AM
