  • 203 Vote(s) - 3.05 Average
Mindy A60 and closing issue
Hi Guys sorry for the first post being this ,I've got a Mindy A60 that has a timer opening at 6.30 am (Gates open) and should close at 21.30.
what's happening is the gates open as they should but when the timer drops out (I can see and have metered it the timer falls away and goes open circuit, the gates don't shut. But to make matters worse not all the time,confused .... yeah me too. If I momentarily short out pin 27 (close) it closes.
I was going to put another timer relay in say at 21.40 just to pulse it closed, but that defeats the object.
All safety features are clear so I'm a little confused.
I also have a ground loop hitting the same open input but that's clear and just to be sure I've put two diodes just in case of feed back.
Thanks again for reading and any help would be great.
Gary
(28-02-2017, 11:35 PM)alarmeng Wrote: Hi Guys sorry for the first post being this ,I've got a Mindy A60 that has a timer opening at 6.30 am (Gates open) and should close at 21.30.
Gary
you could check all safety features /loop/photo/stop.
bridge all nc contact with com temporarily and press handset to close the gate
regards
Gary
Hi Gary,
Couple of questions for you.
Have you got automatic closure set on the panel?
What position are your dip switches in currently?
  Nice MC800 Wiring issue Adamzsite 2 1,164 05-03-2024, 04:37 PM
  Nice photo sensor issue F210 and MC824H gates won’t operate Tantrum 1 2,188 04-01-2024, 10:06 AM
  ROBUS 400 OPEENING CLOSING ISSUES warren203 1 2,567 08-08-2023, 02:16 PM
  NICE MC800 for failed A60 mindy bg148 2 4,924 17-06-2022, 12:25 PM
  IT4WIFI Homekit Issue anx10us 0 3,373 08-12-2020, 09:17 PM
Last Post: anx10us
  Nice TOO7500/ Mindy A60 Installation Problem Woody 1 7,249 22-08-2020, 02:31 PM
Last Post: Woody
  Nice TOO 3000 Gate opener not closing Sully 1 8,448 17-03-2020, 11:34 AM
  Mindy A824 Controller - OK Light Flashing ColinS 5 26,533 02-01-2020, 08:19 AM
Last Post: pronosoft12
  MINDY A60 remote transmitter programming marxfer 9 42,549 09-05-2018, 06:13 PM
  Nice Mindy - One gate doesn't open Danseri 1 12,773 19-01-2016, 11:00 AM
