  • 149 Vote(s) - 3.14 Average
MINDY A60 remote transmitter programming
does anyone has instructions on programming FLO2RE remote clone using the control unit Mindy A60?
I knew that I should be following original programming procedure which is not in the manual.
what do you mean remote clone , is that one frome ebay seller or what ?
(16-09-2017, 08:37 PM)Automatic-TC Wrote: hi
Yes, it is one from ebay not being manufactured by Nice.
take original nice remote which been already programed into A60 and just use clone remote to copy this code from .
or
press down receiver button for 3 sec and relise
now you have 10 seconds to press new remote and hold for 2 seconds
if programing went fine led on receiver will flash three times
Thanks, it seems that programming woth receiver is the only option.
Hence, please give me instructions on to how to open Mindy A60 cover plate.
(21-09-2017, 06:46 AM)marxfer Wrote: Thanks, it seems that programming woth receiver is the only option.
show me how it looks like this device ?
can we have some picture
regards
Please take a look at photos on the page:
https://www.botech-shop.com/control-boar...51725.html
<img src="https://www.botech-shop.com/11150-thickbox_default/control-board-nice-a60.jpg">
(21-09-2017, 04:01 PM)marxfer Wrote: Please take a look at photos on the page:
ok , where is the problem ?
you need only screw driver to unscrew 4 yelow screws and pull cower to open ,cover has hinges on one side like clasic door
Does anyone know how to programme a mindy a60 to full capacity without the second motor being used ? Thanks
there is no programing option only trimmers regulation need it
trimmer TL2 set to minimum (working time second gatewing )
trimmer TRC set to minimum ( opening and closing time delay )
trimmer F motor force
trimmer TP  pause time for automatic closing
make motor conection to 8/9/10 terminal M1
there is also dip-switch terminal from 1 to 10
two first one are important for right working
1/2 off/off manual operation
1/2 on/off semiautomatic
1/2 off/onn automatic (TP trimmer for closing time have to be set )
1/2 on/on automatic ( always closing option)
  NICE MC800 for failed A60 mindy bg148 2 4,809 17-06-2022, 12:25 PM
  Nice remote fob Deb 4 16,502 30-10-2020, 09:59 AM
  Nice TOO7500/ Mindy A60 Installation Problem Woody 1 7,158 22-08-2020, 02:31 PM
Last Post: Woody
  Mindy A824 Controller - OK Light Flashing ColinS 5 26,297 02-01-2020, 08:19 AM
Last Post: pronosoft12
  Nice Remote - Lock out doctorrogeaton 1 9,048 18-05-2019, 08:39 AM
  Mindy A60 and closing issue alarmeng 2 14,389 09-03-2017, 11:41 AM
  MC824H Simple Programming Guide easygates 2 21,441 25-03-2016, 09:43 PM
Last Post: Henwood_1988
  Nice Mindy - One gate doesn't open Danseri 1 12,658 19-01-2016, 11:00 AM
  nice flo4r-s remote control question tibibond 2 16,210 04-03-2013, 10:06 PM
Last Post: tibibond
