  • 226 Vote(s) - 3.08 Average
Mindy A824 Controller - OK Light Flashing
I have a Nice Mindy Controller on my gates. The Gates stopped working and the OK light is flashing a series of 7 or 8 short flashes, a pause and then repeats.
I have powered off the whole system to try and reset, but still same light sequence.
I tried to cancel the memory, to do a reset but it doesn't change.
Does anyone know what that light sequence is trying to tell me?
Hi Colin,
In the bottom right hand side of the Mindy controller you should see a row of 6 LED's. The first 3 of which should be lit, and the remaining three should be off. Could you check these and let me know which are on, and which are off?
Cheers,
Dave
(01-04-2016, 10:30 AM)ColinS Wrote: Hi
Dave Blake
(05-04-2016, 10:11 AM)Blakey111 Wrote: Hi Colin,
Cheers,
Dave
Hi all,
I have the same problem, the 3 led on the lower right are on.
Any fix available.
Paul
Hi All,
I have the same problem with the OK Led flashing approx. 7-8 times then repeating.
The first 3 LED on the lower right are on.
Any diagnosis or fix ?
Heres hoping.
Paul
(03-11-2019, 06:04 AM)PaulB Wrote: Hi All,
Heres hoping.
Paul
Hi Paul,
it could be one of the following possible faults...
7 Flashes -Electric circuits fault -
Wait at least 30 seconds, then try sending a command and if necessary turn off the power supply. If the condition persists, there may be a malfunction and the electronic board must be replaced.
8 Flashes - A command is already present that disables execution of other commands -
Check the type of command that is always present; for example, it could be a command from a timer on the “open” input.
Hope this helps.
Hi Colin,
Cheers,
Dave
  NICE MC800 for failed A60 mindy bg148 2 4,811 17-06-2022, 12:25 PM
  Nice TOO7500/ Mindy A60 Installation Problem Woody 1 7,166 22-08-2020, 02:31 PM
Last Post: Woody
  Aria gate openers and GSM controller Jamie 2 6,479 25-04-2020, 06:19 PM
Last Post: Jamie
  Robus 600 not opening - Bluebus flashing DaveB 1 7,814 27-03-2020, 06:14 PM
Last Post: DaveB
  MINDY A60 remote transmitter programming marxfer 9 41,993 09-05-2018, 06:13 PM
  Mindy A60 and closing issue alarmeng 2 14,395 09-03-2017, 11:41 AM
  Nice Mindy - One gate doesn't open Danseri 1 12,664 19-01-2016, 11:00 AM
  Daitem SC9200AU Controller to Nice MC824 Shropshire fella 2 15,678 27-10-2014, 03:35 PM
