  • 10 Vote(s) - 2.4 Average
Nice TOO7500/ Mindy A60 Installation Problem
Hi All, please bear with me as I’m a keen DIYer not a professional gate installer.
I’ve just installed a Nice 7500 double gate opener with a Mindy A60 control panel.
However, I can’t get the motors to move. I’ve wired everything up as per the instructions but no movement when I press the control.
The LED on the control board is on and flashing and it does a double flash every time I press the control, so I think it’s getting the demand signal okay.
Reading another thread it says put a bridge between terminals 20-22 (common to
Stop). Is this correct? There is currently no wire in 22 which i assume is described as a normally closed input.
Just don’t want to damage the panel by connecting the wrong terminals together.
Thanks for your assistance,
Woody
Resolved. I plucked up the courage and connected together terminals 20-22 and it worked, should anybody else have the same issue.
  nice robus D400 smartphone control YOSH 1 910 05-03-2024, 04:45 PM
  Nice MC800 Wiring issue Adamzsite 2 911 05-03-2024, 04:37 PM
  nice robus troubleshooting tarmongaidon 7 16,859 30-01-2024, 05:19 PM
Last Post: hasanova
  Nice photo sensor issue F210 and MC824H gates won’t operate Tantrum 1 1,898 04-01-2024, 10:06 AM
  Nice Robus RBA3c Wifi Relay Switch Wiring denis 1 2,371 01-11-2023, 09:45 AM
  NICE MC800 Factory Reset bg148 5 3,389 12-10-2023, 01:11 PM
  Nice MCA1 stuck open after stop command Khooke 1 2,650 25-09-2023, 10:47 AM
  Nice transmitters - compatibility Noghar 6 6,793 10-10-2022, 10:02 AM
  NICE MC82H - connecting maglock grangerd 3 4,969 10-10-2022, 09:40 AM
  Nice Robus Don't Auto Close!!!! Ali_1982 1 4,387 03-08-2022, 02:23 PM
