  • 6 Vote(s) - 2 Average
Nice transmitters - compatibility
I am in the process of having new gates fitted with a Nice opening mechanism. The installers have offered me ERA ONE remotes, black and white, but on the EasyGates site I found Era INTI remotes that look similar but are more colourful. My question is, are the INTI remotes/transmitters compatible with an ERA ONE receiver? They seem to use the same frequency but I have not seen the INTI transmitters described as a viable replacement for Era Ones.
Thanks in advance!
(29-09-2022, 05:05 PM)Noghar Wrote: I am in the process of having new gates fitted with a Nice opening mechanism. The installers have offered me ERA ONE remotes, black and white, but on the EasyGates site I found Era INTI remotes that look similar but are more colourful. My question is, are the INTI remotes/transmitters compatible with an ERA ONE receiver? They seem to use the same frequency but I have not seen the INTI transmitters described as a viable replacement for Era Ones.
Thanks in advance!
Good Afternoon,
Thank you for your enquiry.
The inti remotes are essentially a smaller version of the ERA ONE remotes. They will be compatible as they are the same coding and frequency.
Thanks in advance!
Good Afternoon,
Thanks, but I received exactly the opposite advice from tech support at Easy Gates, who said the two transmitters were not compatible, and I would need an additional receiver. So now I don't know what to think. I may buy an inti and try it for myself.
" The Inti remote controls cannot work alongside the standard Era One coding fobs I am afraid, the reason for this is that one style of fob uses the O-Code programming and the other Flo coding and therefore cannot work synergistically.
If you are keen to have both styles you could purchase an additional OX2 radio receiver which will allow for the function of both fobs. "
(30-09-2022, 07:46 PM)Noghar Wrote: " The Inti remote controls cannot work alongside the standard Era One coding fobs I am afraid, the reason for this is that one style of fob uses the O-Code programming and the other Flo coding and therefore cannot work synergistically.
thank you for that information.
Just done some more digging. The ERA one remotes can work with the INTI remotes. But the ERA one remotes will need to be programmed in first them the INTI second.
Hope this helps.
Hope this helps.
You are absolutely right. I have just received an INTI and programmed it from the Era One transmitter with no problems at all.
Moreover the INTI is half the size of the Era One and far easier to keep on a keyring.
Thanks for your help. Smile
Hope this helps.
Thank you for your response,
We are glad that we can be of assistance to you.
  nice robus D400 smartphone control YOSH 1 914 05-03-2024, 04:45 PM
  Nice MC800 Wiring issue Adamzsite 2 914 05-03-2024, 04:37 PM
  nice robus troubleshooting tarmongaidon 7 16,873 30-01-2024, 05:19 PM
Last Post: hasanova
  Nice photo sensor issue F210 and MC824H gates won’t operate Tantrum 1 1,904 04-01-2024, 10:06 AM
  Nice Robus RBA3c Wifi Relay Switch Wiring denis 1 2,374 01-11-2023, 09:45 AM
  NICE MC800 Factory Reset bg148 5 3,393 12-10-2023, 01:11 PM
  Nice MCA1 stuck open after stop command Khooke 1 2,655 25-09-2023, 10:47 AM
  NICE MC82H - connecting maglock grangerd 3 4,972 10-10-2022, 09:40 AM
  Nice Robus Don't Auto Close!!!! Ali_1982 1 4,387 03-08-2022, 02:23 PM
  NICE MC800 for failed A60 mindy bg148 2 4,856 17-06-2022, 12:25 PM
