  • 7 Vote(s) - 2.86 Average
NICE MC800 for failed A60 mindy
My A60 mindy failed and I swapped in an MC800.
When I power it up the bluebus LED is giving 7 short flashes with a one second pause. L1 and L2 are on.  The manual indicates the 7 flashes indicates 'Electric circuit anomaly'
While similar the electrical connections on the MC800 are not the same as the A60.
On the M60 there was a separate 'Common' terminal (terminal 20) to the 24vac terminal (terminal 18) but on the MC400 it looks to be combined with the 24vac terminal  (terminal 4).
The two feeds I had from terminal 18 and 20 on the A60 are both connected to terminal 4 on the MC800 and I am wondering if this is correct?
Any insight appreciated.
Cheers
bg
OK found a video on utube with a similar setup to mine (not in English mind you, but a picture is worth a thousand words). And he had the same flashing leds, however he proceeded with the setup and all came good.
So I followed suite and my gate is now working.
bg
(14-06-2022, 10:58 PM)bg148 Wrote: OK found a video on utube with a similar setup to mine (not in English mind you, but a picture is worth a thousand words). And he had the same flashing leds, however he proceeded with the setup and all came good.
bg
Brilliant, great to hear if there are any further issues do not hesitate to contact us.
Kind regards
  nice robus D400 smartphone control YOSH 1 908 05-03-2024, 04:45 PM
  Nice MC800 Wiring issue Adamzsite 2 908 05-03-2024, 04:37 PM
  nice robus troubleshooting tarmongaidon 7 16,856 30-01-2024, 05:19 PM
Last Post: hasanova
  Nice photo sensor issue F210 and MC824H gates won’t operate Tantrum 1 1,896 04-01-2024, 10:06 AM
  Nice Robus RBA3c Wifi Relay Switch Wiring denis 1 2,369 01-11-2023, 09:45 AM
  NICE MC800 Factory Reset bg148 5 3,387 12-10-2023, 01:11 PM
  Nice MCA1 stuck open after stop command Khooke 1 2,648 25-09-2023, 10:47 AM
  Nice transmitters - compatibility Noghar 6 6,791 10-10-2022, 10:02 AM
  NICE MC82H - connecting maglock grangerd 3 4,969 10-10-2022, 09:40 AM
  Nice Robus Don't Auto Close!!!! Ali_1982 1 4,387 03-08-2022, 02:23 PM
