  • 20 Vote(s) - 2.8 Average
Robus 600 not opening - Bluebus flashing
Hi All,
Hoping you can help me - My sliding gate has stopped working. When you press the fob, the bluebus light flashes green but nothing happens.  If you press the push button which operates pedestrian access the bluebus goes into 4 flashes, pause, 4 flashes which according to the manual is an issue with a stop input.  All batteries are working in the photocells, and all seem to be working normally (when you break the beam the LED stops flashing inside the unit) - although one of them has corroded terminals which I've stripped, cleaned up and now appears to be working fine - following this, I reset the motor to recognise devices as per user manual).  The gate also has bumper edges - the STOP light inside the motor is red, it goes off when you press the bumpers (which according to the manual means they are working ok).
I've also tried the "Man Present" mode using one of the fobs, this does not seem to work either.
I've tried various diagnostics on the phone with the installer and everything they have suggested has not helped.  Obviously with the current COVID lockdown, nobody can come out to look at it for me.
Any help massively appreciated!!!  Smile Smile
Thanks,
Dave
Robus 600 not opening - Bluebus flashing - by DaveB - 27-03-2020, 04:07 PM
  MC800 NOT OPENING FOR WHITELISTED PLATES AFTER FACTORY RESET Wenzo 4 4,088 27-05-2025, 09:09 AM
  Nice Robus 250 HS Fuse Problem GLM 1 4,826 09-05-2025, 01:07 PM
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,917 10-12-2024, 11:29 AM
  WG20S not flashing rolynoworse 1 2,813 18-11-2024, 07:40 PM
Last Post: rolynoworse
  Nice robus not closing Dantay 1 5,198 27-09-2024, 10:17 AM
  Gate stuck after opening. rixman 4 8,410 11-04-2024, 08:10 AM
  nice robus D400 smartphone control YOSH 1 5,524 05-03-2024, 04:45 PM
  nice robus troubleshooting tarmongaidon 7 45,555 30-01-2024, 05:19 PM
Last Post: hasanova
  Nice Robus RBA3c Wifi Relay Switch Wiring denis 1 7,951 01-11-2023, 09:45 AM
