  • 4 Vote(s) - 2.5 Average
Phobos N L BT one leaf won’t open
Hi all,
Out of the blue one leaf on my double gates stopped working, my first response was to change the limit switches, no fix there!
My next response was to call the engineer out, we brainstormed for hours, we swapped over the motor boards, no fix. We swapped over the motors, no fix. We disconnected the intercom, no fix. We finally agreed that the Thalia board might be faulty so I ordered a new one, it arrived and I installed it, it worked perfectly for two day, then, same again, one leaf stopped working. That was two years ago, the time has come now and I really need this fixed as it is stressing me out to the max, next step will be to rip it all out and replace with a new system but the Voice in my head just can’t except defeat. PLEASE HELP ME !
PS, when I run the auto setup both gates opened once, the the faulty one stopped responding while the foot one finished its cycles, the only the good one worked.
The faulty side is the second motor (last to open).
  Ecosol/Kustos doesn't open and close fully? supremee 3 2,434 09-02-2024, 03:12 PM
Last Post: EdwardBab
  BFT LUX2B Intermittent failure to open brookkr 4 8,087 07-09-2023, 08:32 AM
  Phobos motor movement erratic Caesium 1 961 24-08-2023, 01:39 PM
  BFT Thalia ‘Hold Open’ hehasmoments 5 4,356 24-08-2023, 01:38 PM
  Set remote to “only open” gate mark123499 4 3,899 30-05-2023, 01:57 PM
Last Post: mark123499
Exclamation BfT Sub R - No Closing pressure 1 Leaf Bushpig 2 3,227 23-05-2023, 03:48 AM
Last Post: Bushpig
  PHOBOS N Manual Overide Problem Dazrob 3 2,477 06-12-2022, 07:29 PM
Last Post: Dazrob
  BFT controlled gates open but don't close MikeJep 5 19,867 04-01-2022, 09:58 AM
  Phobos reversing after closing Sim75 0 2,337 21-05-2021, 07:04 AM
Last Post: Sim75
  Rigel 6 - doors do not stay open Poweroftaxi 1 9,261 13-04-2021, 02:41 PM
