  • 4 Vote(s) - 3 Average
Phobos motor movement erratic
When my gates open they travel quite smoothly, however when they close the arc of movement seems to be very jerky.
I've tried changing all the speed and decel distance settings up and down in all sorts of combinations but nothing seems to make any positive change.
Anyone got any suggestions before I source a pair of gas dampers to try and smooth out the travel?
(18-08-2023, 03:41 PM)Caesium Wrote: When my gates open they travel quite smoothly, however when they close the arc of movement seems to be very jerky.
Thanks for the message.
what is the model of operators you are using? it could be related to the geometry measurements listed within the manufacturers instructions.
  BFT Eli 250 24V motor running, no movement. Bjorn 1 3,994 30-01-2024, 07:45 PM
Last Post: Peejay
  PHOBOS N Manual Overide Problem Dazrob 3 2,469 06-12-2022, 07:29 PM
Last Post: Dazrob
  BFT Lux 2B FC Motor not opening all the way to stopper jc.34@outlook.com 8 8,552 19-08-2022, 09:30 AM
  BFT Lux 2B FC Motor not closing all the way jc.34@outlook.com 1 3,149 07-03-2022, 11:24 AM
  Phobos N L BT one leaf won’t open BigJC 0 3,098 11-06-2021, 01:33 PM
Last Post: BigJC
  Phobos reversing after closing Sim75 0 2,334 21-05-2021, 07:04 AM
Last Post: Sim75
  New BFT gate motor Mike 0 7,641 11-04-2018, 07:17 PM
Last Post: Mike
  Electric gate motor Ian morris 1 11,482 11-12-2016, 10:29 PM
  BFT Sub R motor wiring diagram Qwest 1 12,006 17-10-2016, 10:08 AM
  Rigel 5 - 1 motor only going in one direction Guy 0 7,468 26-09-2015, 07:03 PM
Last Post: Guy
