  • 6 Vote(s) - 2.17 Average
BFT Eli 250 24V motor running, no movement.
Hi all.
These and have been brilliant but for some reason one side has jammed partially open.
The motor runs constantly (as the gate never activates the limit switch) and the gate moves easily when I use the release key to manually open and close the gate. This motor has always been really quiet and smooth when compared to the other side.
I’m guessing some kind of gear has stripped/failed and was wondering if anyone has had a similar problem.  If there’s nothing wrong with the motor I’d ideally just like to replace the component rather than whole motor/housing as I see some spares are available.
Thanks in advance.
Bjorn
(19-02-2020, 11:18 AM)Bjorn Wrote: Hi all.
Thanks in advance.
Bjorn
Hi Bjorn,
I am having exactly the same issue as you described.
What ended up being the solution for you?
Thanks!
  Phobos motor movement erratic Caesium 1 960 24-08-2023, 01:39 PM
  BFT Lux 2B FC Motor not opening all the way to stopper jc.34@outlook.com 8 8,565 19-08-2022, 09:30 AM
  BFT Lux 2B FC Motor not closing all the way jc.34@outlook.com 1 3,152 07-03-2022, 11:24 AM
  New BFT gate motor Mike 0 7,643 11-04-2018, 07:17 PM
Last Post: Mike
  Electric gate motor Ian morris 1 11,486 11-12-2016, 10:29 PM
  BFT Sub R motor wiring diagram Qwest 1 12,008 17-10-2016, 10:08 AM
  Rigel 5 - 1 motor only going in one direction Guy 0 7,469 26-09-2015, 07:03 PM
Last Post: Guy
  BFT Altair-P with Phobos motor doesnt stop after closing earthdog 2 17,696 27-11-2014, 01:58 PM
Last Post: earthdog
  BFT SUB Motor test. bbcobmike 1 13,383 09-06-2014, 03:01 PM
Last Post: thm
