  • 195 Vote(s) - 2.93 Average
BFT Sub R motor wiring diagram
Hi, does anyone have a wiring diagram for the Sub R?
I have a pair of motors I wish to bench test before installing and need to know what function each wire has.
I have wires coloured brown, black, green together with green and yellow earth.
I am guessing we have line, neutral and a second line for reverse but just want to check before testing.
On the same subject - is there a standard / generally accepted bench test for these motors?
Bit of further background.... motors concerned are dated 2004 and I am replacing them but I want to test both to see if either are worth keeping as a replacement motor as I am replacing with the same model. I just want to know whether to keep or discard.
Thanks!
You can find all the manuals you require on our manuals page.
http://manuals.easygates.co.uk/bft-sub/
hope this helps.
  BFT Eli 250 24V motor running, no movement. Bjorn 1 3,976 30-01-2024, 07:45 PM
Last Post: Peejay
  Phobos motor movement erratic Caesium 1 939 24-08-2023, 01:39 PM
  BFT Lux 2B FC Motor not opening all the way to stopper jc.34@outlook.com 8 8,519 19-08-2022, 09:30 AM
  BFT Lux 2B FC Motor not closing all the way jc.34@outlook.com 1 3,135 07-03-2022, 11:24 AM
  bft 2b kit wiring mcw1965 2 16,439 04-01-2021, 02:26 AM
Last Post: Bobby2
  Altair-P gates now move in opposite direction with any change to wiring william.helsby 1 6,873 24-05-2020, 08:08 PM
Last Post: william.helsby
  Wiring Compacta photocells to Rigel 5 rjmoore 0 10,916 11-05-2020, 06:51 PM
Last Post: rjmoore
  New BFT gate motor Mike 0 7,624 11-04-2018, 07:17 PM
Last Post: Mike
  Electric gate motor Ian morris 1 11,473 11-12-2016, 10:29 PM
  Rigel 5 - 1 motor only going in one direction Guy 0 7,455 26-09-2015, 07:03 PM
Last Post: Guy
