  • 196 Vote(s) - 2.93 Average
BFT Gate issue
#11
Hi, In your problem is the sensory fine cor in the motor, you have to adjust the opening angle of the sensory fine cor.
In VietNam when you meeting the same error for product of bft call me (+84)0904 668 997 or visit our website https://automaticdoor.vn
Hi!
I have the same issue in reverse, i.e. the first gate closes well in Summer but does not reach the stop in Winter. The other gate pushes it to the stop.
Reading the above comments, along with my personal experience with BFT, I believe their after sale service is inadequate to say the least.
This being out of my chest I am looking for explanations of the phenomenon. The gates have each an electric motor which are, my understanding, working as a function of time. The setting is the same for both motors. Let's say that one -for mechanical reasons- is slower than the other motor, the attached gate will travel less. Hence the issue.
To cure this problem, I have disassembled the chain which was rusted and the closings and openings are smoother (although there is some grinding noise which scares the hell out of me as the price of the whole mechanism is pretty expensive). But the issue remains.
Now, what about the oil mentioned previously. Has anybody an idea about its function?
Happy new year to all!Smile
strange noise , when the last maintenance was done ?
i recommend complete maintenance . you can do it yourself
clean all ,change the oil ,set new operation times
Happy new year
Best Regards
Tom
Thank you Automatic-TC!
I suppose the noise correspond to either the worm gear missing a tooth (?) or the ball bearings being rusted.
I'll be conducting a complete overall as soon as the weather will cooperate! ;-)
I shall be reporting here the result of my actions.
The weather is slightly cooperating (30ºC). So, I dismantled one the gate mechanism and tested the chain once more. After cleaning it thoroughly I discovered that the rollers are completely seized! I don't even think that the second mechanism is in better condition. Therefore I am looking for two new chains. BFT is not selling them. It seems that only one seller (theelectricgateshop.co.uk) has the item in their catalog at the price of £33.60 each. This is way too much, I think, for a low quality (not motorbike chain quality) chain. I am listening to any suggestion as where to find a better price.
Second point of interest: it seems that the chain is used and being positioned in an horizontal plan, the slack (sideways) of the chain makes it conflicting at times between the chain flange and the sprocket, hence slowing the whole rotation leading to the issue mentioned at the beginning of my posts. I believe that a new chain should solve this issue. If necessary I'll find a way to prevent this to happen.
Thanks. I'll keep you posted.
  Gate wont close issue MR_ROBOT 3 9,880 11-04-2024, 08:08 AM
  Bft gate problem djkokalis 1 1,380 14-02-2024, 12:39 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 1 1,054 14-02-2024, 12:18 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,250 04-01-2024, 10:21 AM
  BFT sliding gate intermittent operation vozm100 5 2,301 02-10-2023, 09:08 AM
  Set remote to “only open” gate mark123499 4 3,943 30-05-2023, 01:57 PM
Last Post: mark123499
  Parallel (or not) gate motors Ian Evans 1 2,506 16-05-2022, 11:44 AM
  BFT Thalia GSM gate opener SunnyB1 1 3,052 07-03-2022, 10:58 AM
  BFT gate won't stop mid way redgraysie 0 3,120 10-12-2020, 12:56 PM
Last Post: redgraysie
  BFT Rigel 5 Issue kw1 0 9,651 16-08-2020, 02:04 PM
Last Post: kw1
