  • 242 Vote(s) - 3.05 Average
BFT controlled gates open but don't close
Hi all - we've a couple of swing arm gates controlled by a BFT Aries. The system is about 20 years old but has been reliable till now.
Recently the gates opened then wouldn't shut. We could unlock the arms and manually shut them ok. Once locked again they would open on demand perfectly but, once open fully, wouldn't close again. There is plenty of ticking going on from the relays as the shut cycle is supposed to happen and there is even power to the motors (haven't tested polarity) - but no movement. The gates move freely once unlocked
Any ideas much appreciated.
(16-09-2016, 02:33 PM)MikeJep Wrote: Hi all - we've a couple of swing arm gates controlled by a BFT Aries.  The system is about 20 years old but has been reliable till now.
Hi!  Having this same problem you describe. Did you ever get yours figured out?
(31-05-2020, 05:52 AM)John24hr Wrote: Hi!  Having this same problem you describe. Did you ever get yours figured out?
same issue here but BFT Rigel 5
one gate was jammed by snow - clear now
it closes manually then opens with the FOB and stays open with no fault code
read somewhere about a safe mode that gates stay open??
any suggestions Sad
Can you see any fault codes on the panel? If not, I would recommend running the motors on new cabling directly into the board, as well as your safety devices and photocells.
Reset the panel and see if this works, if so, it is more than likely a cabling issue. If not, the board is probably faulty due to the age. I would also say if you have x2 motors you can learn these in single mode, so if it is a motor fault you will be able to determine this.
-Jamie
  Gate wont close issue MR_ROBOT 3 9,932 11-04-2024, 08:08 AM
  Ecosol/Kustos doesn't open and close fully? supremee 3 2,519 09-02-2024, 03:12 PM
Last Post: EdwardBab
  Thalia - Photocell Close J to the D 1 922 19-01-2024, 09:54 AM
  BFT LUX2B Intermittent failure to open brookkr 4 8,138 07-09-2023, 08:32 AM
  BFT Thalia ‘Hold Open’ hehasmoments 5 4,401 24-08-2023, 01:38 PM
  Set remote to “only open” gate mark123499 4 3,970 30-05-2023, 01:57 PM
Last Post: mark123499
  Gates not fully closing stefen1978@hotmail.co.uk 2 2,791 10-10-2022, 10:07 AM
  RCD trip on close LUX 2B DP86 3 6,752 14-04-2022, 08:55 AM
  Best BFT for closed aluminium gates rafp 1 3,049 13-04-2022, 11:38 AM
  Remote only working close up Uphill 0 2,667 03-10-2021, 07:50 PM
Last Post: Uphill
