  • 218 Vote(s) - 2.72 Average
proteco Q60AR fault
My gate suddenly stopped to work and the prompt in the Q60AR display is: -0
This error code does not compare in the manual and I do not know what it means.
If I push the switch A in the Q60AR board for 5 times (a complete round trip of menu) and then I command the gate to open, with my remote or with the key, it works and it performs a complete open-and-close gate cycle. But only once! Afterwords it stop again to accept any command. So if I want to open again I need to push again the switch A in the board (again a complete round trip of the menu).
Any suggestion to solve the problem?
  TC fault code on Q60ar control board Skydive1710 3 3,653 20-11-2023, 03:12 PM
Last Post: NormanY
  FAAC E124 fault 05 allan@amtas.com.au 0 774 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 18,073 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 995 19-06-2023, 01:03 PM
Last Post: xCO
  Q80A Fault Code kevcl15@yahoo.co.uk 1 2,071 03-02-2023, 12:00 PM
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 4,066 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 3,198 12-07-2022, 11:48 AM
  Q80A Strange fault. Cannot work it out, if setting or fault? gray 0 1,487 25-06-2022, 08:14 AM
Last Post: gray
  Proteco Q60 - FH error then close after opening Needlerp 1 2,427 24-06-2022, 09:54 AM
  proteco q60a microcontroller program arashkhan 1 2,632 17-06-2022, 01:29 PM
