  • 6 Vote(s) - 3 Average
Proteco controller & ACT5e keypad - keeps tripping
  • Proteco controller
  • ACT5e keypad
Had system in for 10 years but on two occasions (one a number of years ago and one now) the key pad (ACT5e) is tripping the resettable fuse on the board
All worked fine until earlier this week - now on connecting the keypad to the board the board trips and has to be reset (powered off and on again)
no shorts detected
no obvious cable degradation etc
key pad works ok when powered up on its own from a separate supply (but I've not measured current draw etc )
Thoughts
is the resettable fuse a bit sensitive - do they degrade over the years ?
All ideas welcome
Francis
Ireland
Any thoughts any one
(14-08-2022, 10:01 PM)fclauson Wrote: Any thoughts any one
Thanks for the message,
it is possible that this may need replacing however it is extremely unlikely, i would probably assume the issue lies with the cabling to the keypad itself shorting causing a low resistance which subsequently will cause the current to rise, do the gates still operate via fobs without issues?
Thanks for this
The system works perfectly without the keypad connected.
I have connected the keypad to an old physics lab power supply where I can read off the current draw - it seems in order at around 50 to 80ma.
I am going to circumvent the installed cable and run a quick test cable keypad directly to the box to see if as you suggest, there is some issue in the installed cable. I've always had a suspicion this cable was compromised on installation but its failure is intermittent (perhaps weather or moisture dependant etc)
(20-08-2022, 06:23 AM)fclauson Wrote: Thanks for this
thanks for the reply,
please keep me updated with your findings.
Kind Regards
  Identify controller/PCB? Jack.toland 4 871 18-01-2024, 11:58 AM
Last Post: Jack.toland
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 18,011 26-09-2023, 05:32 AM
Last Post: max666
  Rigel 5 - second keypad stopped working HarefieldHse 1 1,607 03-07-2023, 08:48 AM
Exclamation Proteco Q60A stopped working xCO 0 977 19-06-2023, 01:03 PM
Last Post: xCO
  Controller CL20S replacement Kaala1 6 4,950 15-03-2023, 09:23 AM
  Ditec VIVAH controller Bollidear 1 1,548 07-11-2022, 11:12 AM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 3,152 12-07-2022, 11:48 AM
  Proteco Q60 - FH error then close after opening Needlerp 1 2,390 24-06-2022, 09:54 AM
  proteco q60a microcontroller program arashkhan 1 2,601 17-06-2022, 01:29 PM
  Proteco Q60 AR ...Fob wont program Shane1 0 1,737 12-01-2022, 08:13 PM
Last Post: Shane1
