  • 2 Vote(s) - 1.5 Average
Proteco Q60 - FH error then close after opening
Hi, I've got a Proteco Q60 dual swing gate controller. I recently had a problem where the power supply was cut to the closing photocell transmitter.   I repaired it today and the LED now goes back to '--' as expected. When I sent a close signal by linking 1-8 for a second, the LED goes to Go and the gate opens/closes as expected. However about 3-4 seconds after the gate fully opens/closes, I see FH appear momentarily on the LED, and then the gate does the reverse action.
I've tried removing all external devices and shorting the basic links (2-8, 4-9, 3-9) and testing manually by touching 1-8. Same issue - so I don't believe it's anything to do with the photocell circuit or any external switches.
Can anybody give me any indications as to what might be causing this error? The manual just says that FH is dual opening/closing photocell interruption or wiring error, but as it happens even when I have jumpers across 4-9 and 3-9 I don't believe that's the issue.
Thanks in advance for your help!
Paul
Hope you are well. We do not tend to deal with Proteco systems, I would recommend getting in touch with them directly - http://proteco-direct.co.uk/support/
- Jamie
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 18,013 26-09-2023, 05:32 AM
Last Post: max666
  Gates Opening After Closing tht7 2 9,653 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
Exclamation Proteco Q60A stopped working xCO 0 977 19-06-2023, 01:03 PM
Last Post: xCO
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 4,011 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 3,152 12-07-2022, 11:48 AM
  proteco q60a microcontroller program arashkhan 1 2,601 17-06-2022, 01:29 PM
  Aria 400 - gates keep opening and closing objohnuk 1 4,210 13-04-2022, 11:32 AM
  Proteco Q60 AR ...Fob wont program Shane1 0 1,737 12-01-2022, 08:13 PM
Last Post: Shane1
  Came ZLJ24Z - close immediately photocells are clear Enginear1 0 1,976 29-10-2021, 10:47 PM
Last Post: Enginear1
  Proteco Leader N1 problem Luc Bevers 0 2,064 22-10-2021, 09:57 AM
Last Post: Luc Bevers
