  • 32 Vote(s) - 2.56 Average
Gates Opening After Closing
I am having a problem with my FAAC gates (245 board). The issue is that the gates will automatically open on their own about 5-8 seconds after they are closed. It seems to be that if the gates have been open for a while (over half an hour) then they will not reopen on closing. However, if you open the gates, go through, and then close them, they will reopen. You have to repeat the process another 1-2 times until they decide to remain closed. The temperamental nature of it is a real head-scratcher.
Any ideas what could be causing this? The photocells aren't configured at the moment but I don't believe this would be the cause.
Any help massively appreciated!
(15-04-2017, 07:39 PM)hi did you ever get this fixed, as i also have the same issue on a differnt board (BFT Libra ) my pair gates open again right away when they come to close and straight after a "Start" is sent to the board and the gates open? photocells all work as intended any help appreciated Wrote: Hi,
(13-10-2021, 04:47 PM)Hi,I having this same problem with faac 245 board. Did you guys found out the solution?  Thanks in advancegate-keeper Wrote:
  Rigel 5 , gates won't open Nameloc 2 3,775 23-04-2024, 08:35 AM
  Gates tripped Phil.c 2 216 22-04-2024, 11:27 AM
  Came ZA3 gates stuck open Ivorwindybottom 0 378 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 1,623 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 8,970 07-01-2024, 07:11 PM
Last Post: Simon NW
  Nice Gates not closing StuL 1 1,582 24-08-2023, 01:34 PM
  LIFE AC4 Closing Issues dilbertdog 0 688 29-07-2023, 02:59 PM
Last Post: dilbertdog
  Came gates stuck open. Ring8180 7 17,047 23-02-2023, 01:08 PM
  Robus 600 not closing fully All Well 11 9,190 03-08-2022, 02:42 PM
  Proteco Q60 - FH error then close after opening Needlerp 1 2,393 24-06-2022, 09:54 AM
