  • 10 Vote(s) - 3.1 Average
TC fault code on Q60ar control board
Hi.
After 8 years of faultless service my gates wouldn't open due to an issue with the Photocells.
The control board is a Q60ar and the fault code is TC.
I've done all the standard checks, Photocells clean inside and out, transformer output is 24v
I've removed Photocells and gates work fine I managed to borrow working Photocells and wired them up but still getting TC fault code.
Im wondering if anyone knows of any other issues that may cause this fault. Also does anyone know what the voltage should be at connection points 8 and 9 on the control board?
(03-02-2023, 09:04 PM)Skydive1710 Wrote: Hi.
You should be getting 24Vdc. The TX side will be wired as follows (9 +24v and 10 negative 24v). The RX side will be wired as follows (8 as +24v and 10 as negative 24v)
The Normally closed (NC) from both side will go into terminal 3 and the common from both photocells go into terminal 8.
Make sure you cables don't have any breaks in (test continuity), alignment is fine and no obstacles in the way and also clean the covers to make sure no condensation on them.
Hi Sam,
I have the same problem, did you ever get it fixed? I knoew it was a while ago
Paul
I've done all the standard checks and how long does phentermine stay in your system, Photocells clean inside and out, transformer output is 24v
Hi Sam,
Paul
I am also looking for the answer of this thing.
But did not find the answer here.
  Fried control board nickfr 3 538 22-03-2024, 12:53 PM
  Computer controlled control panel dsbhachu1 0 263 18-02-2024, 11:35 AM
Last Post: dsbhachu1
  BFT key pad not communication with digital board niall.paul@yahoo.co.uk 1 458 14-02-2024, 12:21 PM
  Faac 452 pcb board benner91 2 1,795 09-02-2024, 06:13 PM
  FAAC E124 fault 05 allan@amtas.com.au 0 748 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 18,012 26-09-2023, 05:32 AM
Last Post: max666
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 3,576 25-05-2023, 03:55 PM
  Replacement Q60A board? ndyhzlwd 1 1,932 10-02-2023, 03:19 PM
  Q80A Fault Code kevcl15@yahoo.co.uk 1 2,037 03-02-2023, 12:00 PM
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 4,180 02-12-2022, 02:51 PM
