  • 297 Vote(s) - 2.79 Average
Gate closing but not opening
Question
Hi, I have a BFT Sliding Automatic gate with Deimos motor using Mitto fobs for remote opening / closing. Installed about 5 years ago. Gate is opening but not closing. It moves about 6 inches back to close and then gets stuck ? What should I check or look for please ? Simple instructions please I'm a woman ! ALL advice very Smile welcome.
Kindest Regards,
Dave
Dave Blake
Thank you Dave. Will try and let you know.
(12-06-2014, 09:26 AM)Blakey111 Wrote: Hi,
Kindest Regards,
Dave
Hi Dave
Problem solved. It was the spring that was disengaging from the bent "arm"....thank you for your help...Smile
Kindest Regards,
Dave
  BFT Sliding Gate randomly opening and closing AdrianMate 2 1,268 Yesterday, 10:30 AM
Last Post: Adamit
  Gate wont close issue MR_ROBOT 3 10,120 11-04-2024, 08:08 AM
  Bft gate problem djkokalis 1 1,579 14-02-2024, 12:39 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,412 04-01-2024, 10:21 AM
  BFT sliding gate intermittent operation vozm100 5 2,498 02-10-2023, 09:08 AM
  BFT opening problem 8 45,882 08-08-2023, 02:14 PM
  Set remote to “only open” gate mark123499 4 4,125 30-05-2023, 01:57 PM
Last Post: mark123499
Exclamation BfT Sub R - No Closing pressure 1 Leaf Bushpig 2 3,304 23-05-2023, 03:48 AM
Last Post: Bushpig
  BFT SubR not opening/closing sometimes Jimmyboy4 3 3,104 09-01-2023, 10:29 AM
  Gates not fully closing stefen1978@hotmail.co.uk 2 2,849 10-10-2022, 10:07 AM
