  • 267 Vote(s) - 2.91 Average
Gate not always shutting - LUX FC-2B
If we pause this gate on it's opening cycle, it always closes properly. If we let it open fully (without interruption) then SOMETIMES it does not close properly.
Is this about "opening pressure"? Or do we need to fit an opening limit stop (like a large rock?)?
Thanks!
(08-04-2012, 09:17 AM)ccl Wrote: If we pause this gate on it's opening cycle, it always closes properly. If we let it open fully (without interruption) then SOMETIMES it does not close properly.
Thanks!
This Gate System Will need open and close stops or it does not have a fixed possition to open too and can over run resulting in the gate not closing properly. This is a general rule for most Arm type motors that they need fixxed stops to move against so they cannot go past there limits. Using this system without the stops may cause damage to the hydraulic seals in the motor and would be a very expensive repair. I would disable the system and get stops fitted then reprogramme the system to work to the new limits.
  Gate wont close issue MR_ROBOT 3 9,850 11-04-2024, 08:08 AM
  Bft gate problem djkokalis 1 1,366 14-02-2024, 12:39 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 1 1,042 14-02-2024, 12:18 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,238 04-01-2024, 10:21 AM
  BFT sliding gate intermittent operation vozm100 5 2,282 02-10-2023, 09:08 AM
  Set remote to “only open” gate mark123499 4 3,928 30-05-2023, 01:57 PM
Last Post: mark123499
  Parallel (or not) gate motors Ian Evans 1 2,501 16-05-2022, 11:44 AM
  BFT Thalia GSM gate opener SunnyB1 1 3,047 07-03-2022, 10:58 AM
  BFT gate won't stop mid way redgraysie 0 3,118 10-12-2020, 12:56 PM
Last Post: redgraysie
  Gate won't close on manual or auto Baz1981 0 5,940 23-06-2020, 05:27 PM
Last Post: Baz1981
