  • 423 Vote(s) - 2.84 Average
Mag lock problem
Hi All
I have a set of 240v gate motors on a CB1 controll box. At the weekend we had a power cut and since then the maglock relay pulses on and off the gates open and close as normal all photo cells are ok just the maglock. For the moment I have pulled the relay out to stop it.
Also the red led to the right of the transformer is pulsing if this means anything.
Any help will be appretiated.
Many thanks.
Rich
This sounds like the power cut has resulted in a power surge and blown the PSU that is powering the Magnetic Lock and you will need a new PSU hopefull the power surge has not damaged the magnetic lock but without trying a new PSU you wont know
  Diagram for mag lock on a CB124EV Defender 8 7,912 12-07-2022, 11:40 AM
  Problem with delay time CB11 milan 2 10,956 04-10-2021, 01:44 AM
Last Post: DesmondVog
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 30,840 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  CB22 problem??? Bakota 0 9,282 16-11-2014, 02:25 PM
Last Post: Bakota
  Remote problem Nickhh 1 9,930 30-09-2014, 04:48 PM
  liftmaster CB11 hold gate open problem sparkey 5 30,614 13-05-2013, 08:17 AM
Last Post: brucekwilles
  Problem with CB11 Board Michael 1 11,625 08-05-2013, 11:32 AM
  Chamberlain Liftmaster gate problem CB1 tentotwo 1 13,009 28-03-2012, 12:55 PM
  CB11 Programming Problem dwanee 1 11,957 19-04-2011, 03:59 PM
  Mag lock wiring diagram for SCS300k elliot330 1 17,908 28-05-2009, 10:38 AM
