  • 449 Vote(s) - 2.75 Average
Mag lock wiring diagram for SCS300k
Has anyone fitted a magnetic lock to their SCS300k gates.
I want to fit a lock that energises once the gates have shut, thus locking them together and making them more secure.
There are some contacts on the control board for a lock, but not sure if they have enough power to control the lock, or whether I need to fit a relay etc - Anyone got a wiring diagram?
Elliot
PS. This is the old/original style kit
Hi, When you say old style kit do you mean the 230V kits?
If so you probably have the CB11 control board. To attach a maglock to this board you will need a power supply to power the lock and a 230V relay. you can purchase both of these of us by calling Easygates on 0845 054 50 70. I have attached a diagram of how to wire the maglock using the power supply and relay.
Hope this helps
  Diagram for mag lock on a CB124EV Defender 8 7,866 12-07-2022, 11:40 AM
  Liftmaster SCS300K - stop/go mtuk100 1 12,876 18-04-2017, 09:31 AM
  Wiring relay to CB24 magga 4 20,493 01-08-2012, 06:35 PM
Last Post: magga
  Mag lock problem richc 1 11,924 27-01-2011, 05:53 PM
  Wiring Photocells on the CB11 control board Sparky 2 21,987 28-06-2009, 10:19 PM
Last Post: Sparky
  Mag lock 1 14,478 27-04-2009, 10:43 AM
  Which lock to use to stop gate moving in the wind marknjo 1 15,363 09-01-2009, 03:20 PM
  SCS 300 / 24 & Viro Lock 1 10,867 05-11-2008, 11:04 AM
