  • 264 Vote(s) - 2.81 Average
Wiring relay to CB24
Hi everyone,
I have some SCS300K 24v openers, and am looking at getting the following:
http://www.lightwaverf.co.uk/LightwaveRF...LW821.html
How would I go about wiring this up to the CB24 board? I assume it would be wired a similar way to a key switch etc?
The wiring instructions for it can be found here:
http://www.lightwaverf.co.uk/files/downl...0Relay.pdf
Thanks!
(18-07-2012, 10:38 PM)magga Wrote: Hi everyone,
Thanks!
What are you trying to do with this device. Do you want it to open and hold open your gates or just to control gates. Tjis is not an ideal solution as this is a latching reciever ie it switches on then stays switched on untill triggered again or timmer is set so if used to control the Cb24 the gates would open and hold open untill you trigger the device again.
Hi Mark,
I was planning on using it just like a remote e.g one press to open and one press to close. It says it can be used to on garage doors, so I assumed it could also be used with gates?
Cheers
Matt
(20-07-2012, 12:06 PM)magga Wrote: Hi Mark,
Cheers
Matt
If it is a voltage free output from the unit the wire it accross the
Open and common connectors on right hand side for the board and that will trigger the gate every time those contacts are switched.
Hi Mark,
Thanks for that.
So it's not possible to use it to actually control open, close and stop commands separately? You'd only be able to use it essentially as Single Button Control?
Matt
  CB24 delay to close random fault stuartdsutton 0 8,491 23-09-2015, 11:38 AM
Last Post: stuartdsutton
Rolleyes Chamberlin Liftmaster Professional (CB24 & dual LYN400.24v) SDL 4 28,596 29-12-2013, 02:26 PM
Last Post: Tussun
  Liftmaster Professional CB24 / LYN400 24v - RPM Reversal Error jrhodes310 1 13,023 20-08-2012, 09:40 AM
  cb24 photocells devonaloan 1 11,226 28-11-2011, 05:57 PM
  Liftmaster CB24 key switch Mel1962 2 15,585 25-10-2011, 09:52 PM
Last Post: Mel1962
  CB24 Problems andydday 3 18,251 06-02-2011, 11:39 AM
Last Post: Guest
  CB24 Kit with a single set of photocells JD1765 1 17,867 07-06-2010, 10:04 AM
  CB24 / EasyBKA cliff finch 2 14,128 25-03-2010, 09:25 PM
Last Post: cliff finch
  CB24 Stopped Responding TimL 5 23,552 19-11-2009, 05:22 PM
Last Post: adambrown81
  Wiring Photocells on the CB11 control board Sparky 2 21,960 28-06-2009, 10:19 PM
Last Post: Sparky
