  • 271 Vote(s) - 2.67 Average
Problem with CB11 Board
Got a twin leaf gate with sub 300,s; has worked for about 5years now,but recently changed an aerial in doing so must have upset something. The learn timer light is blinking tried reprogramming using L1 but runs through all 9 stages of programme, all lights flash, go out, and learn timer starts blinking again. Tried using a jumper at jumper 1(10) also tried jumpers across all 3 at right hand side of LED Lights. But still no joy, run through the programme and learn timer light continues blinking. Press the intercom button or press the remote button, start 1 lights up but nothing happens. Just learn timer keeps blinking. Can anyone help me with this thanks
(06-05-2013, 02:06 PM)Michael Wrote: Got a twin leaf gate with sub 300,s; has worked for about 5years now,but recently changed an aerial in doing so must have upset something. The learn timer light is blinking tried reprogramming using L1 but runs through all 9 stages of programme, all lights flash, go out, and learn timer starts blinking again. Tried using a jumper at jumper 1(10) also tried jumpers across all 3 at right hand side of LED Lights. But still no joy, run through the programme and learn timer light continues blinking. Press the intercom button or press the remote button, start 1 lights up but nothing happens. Just learn timer keeps blinking. Can anyone help me with this thanks
With the Learn/Timmer flashing all the time this is stuck in learn mode and sounds like the logic on the board is corrupted. Only sujestion is to remove all accessories from the system and just run it with motors attatched and try re programme the system. If this fails you will need a new circuit board
  CB11 Multiple Keypad support Pigsfoot 1 2,206 12-08-2022, 08:14 AM
  Problem with delay time CB11 milan 2 10,897 04-10-2021, 01:44 AM
Last Post: DesmondVog
  Which original remote control is suitable for board CB124 Evan 3 9,698 20-06-2019, 04:26 PM
Last Post: Devs
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 30,750 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  LiftMaster SUB300M + CB11 fault jonesy1991 0 10,814 25-01-2016, 02:51 PM
Last Post: jonesy1991
  Opening delay on SCS300 (CB124 board) willows79 0 8,681 02-12-2015, 09:45 PM
Last Post: willows79
  CB11 controller BrianP 2 13,848 16-09-2015, 08:58 AM
Last Post: Gateguy
  CB22 problem??? Bakota 0 9,261 16-11-2014, 02:25 PM
Last Post: Bakota
  Remote problem Nickhh 1 9,896 30-09-2014, 04:48 PM
  liftmaster CB11 hold gate open problem sparkey 5 30,395 13-05-2013, 08:17 AM
Last Post: brucekwilles
