  • 421 Vote(s) - 2.9 Average
CB11 Programming Problem
Hi All,
I have a single Sub300 Motor operating a single leaf gate, a Magnetic Lock, 2 sets of Chamberlain Photocells all operated using a CB11 control board. The system is set in Standard operating mode. The problem I am having is setting the soft stop/slow run. Each time I try to Program the "Advanced" distance covered according to the manual using the L1 button the board is not remembering the Soft stop timings. As a result the gate is slamming back against the Kerb and has sheared the bolt holding the arm in place in the Sub300 box. The gate is also hitting the Magnetic lock with force and will not slow run against the lock. Could there be a fault with the board itself or am I missing something in the set up?
Sounds like a setup problem it can be arkward to programme single gate as the instructions are a little confussing. You need to programme the open then wait for 30 seconds for the board to realise that its a single gate then program the close limits and slow down
  CB11 Multiple Keypad support Pigsfoot 1 2,205 12-08-2022, 08:14 AM
  Problem with delay time CB11 milan 2 10,897 04-10-2021, 01:44 AM
Last Post: DesmondVog
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 30,750 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  LiftMaster SUB300M + CB11 fault jonesy1991 0 10,814 25-01-2016, 02:51 PM
Last Post: jonesy1991
  CB11 controller BrianP 2 13,848 16-09-2015, 08:58 AM
Last Post: Gateguy
  CB22 problem??? Bakota 0 9,261 16-11-2014, 02:25 PM
Last Post: Bakota
  Remote problem Nickhh 1 9,896 30-09-2014, 04:48 PM
  liftmaster CB11 hold gate open problem sparkey 5 30,393 13-05-2013, 08:17 AM
Last Post: brucekwilles
  Problem with CB11 Board Michael 1 11,583 08-05-2013, 11:32 AM
  Chamberlain Liftmaster gate problem CB1 tentotwo 1 12,976 28-03-2012, 12:55 PM
