  • 198 Vote(s) - 2.8 Average
Gate Controls/Indicators 200m from Gates
2) Gate open light (240v)
Morning!
I hope this helps.
EasyGates.co.uk
EG Direct - Trade only
Thanks Ryan.
The other problem we have is that the gate is out of sight from the house from  Although it's only 200m in a straight line, it is roughly a 500m walk to get from the house to a point where you can see whether the gate is open or not.
That is quite a distance.
I agree with you mate, it will be difficult to get a strong signal with that distance
Hi, have you possibly tried using a designated Ariel to boost signal strength.
#9
#10
  SEAV LRX-2186: gate opens a bit then stops mehsom 2 778 09-01-2026, 10:38 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 31 61,875 09-01-2026, 10:03 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,510 11-11-2025, 04:41 PM
  I want to know Best Gate Lock for Security? mitasali 0 5,097 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,667 18-03-2025, 06:40 AM
