  • 26 Vote(s) - 3.12 Average
Gates not staying open
We have what I believe is a Daitem SC901 wireless intercom controlling a set of gates with Nice in ground motors at our house. They have an IR beam to the inside of them and for the last 10 years if we have wanted to keep the gates open we have just covered one of the IR sensors. However recently the gates have started shutting after the set amount of time even when the IR is covered.
I assumed the IR was faulty but you can hear the relay click if you break the beam, and if you break the beam whilst the gates are closing then they open fully again. I can't see anywhere in the manual for a setting for any sort of IR override so am stumped.
Any ideas what might be the issue?
(09-05-2025, 06:26 PM)JimM169 Wrote: We have what I believe is a Daitem SC901 wireless intercom controlling a set of gates with Nice in ground motors at our house. They have an IR beam to the inside of them and for the last 10 years if we have wanted to keep the gates open we have just covered one of the IR sensors. However recently the gates have started shutting after the set amount of time even when the IR is covered.
Hi Jim,
If the photocells are working as they should I am not sure why they are reclosing if they are covered, how long after the photocells have been covered does the gate reclose?
An easier way to keep the gates opened without them closing is to give them another command from your remote just before they completely open. This will give the gates a stop command and keep them from closing before another command is given.
Jake
  FAAC gates out of sync TheDock 1 3,473 21-08-2024, 12:21 PM
Last Post: TheDock
  Nice MC824H gate stuck open Markp80 1 5,970 13-05-2024, 02:32 PM
  Rigel 5 , gates won't open Nameloc 4 10,261 04-05-2024, 12:41 PM
Last Post: Alee
  Gates tripped Phil.c 3 6,156 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 3,089 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 8,130 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 15,037 07-01-2024, 07:11 PM
Last Post: Simon NW
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 9,107 02-10-2023, 09:20 AM
  Nice Gates not closing StuL 1 8,255 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 15,690 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
