  • 11 Vote(s) - 3 Average
Faac 740D, Open further then limit, not closing
I have a sliding gate with a FAAC 740D control board.
The issue: the gate only opens, even when the led indication is showing closing (06)
When the gate is manual moved to close or to open this is correctly displayed on the LED display.
When the gate is manual moved in the middle position the both FCA & FCC led light up correctly
When the gate is Manual placed in closed position and the remote is pressed the gate moves to open.
It then slows down when the end switch (magnet) is near and it stops correctly at the end stop. (full open position is reached)
Then it's indicating 04 on the led, a timer counts and after 30 seconds the gate continues to open further.
The indication at this time on the LED is 06, this should be in the closing direction but instead it moves to open.
This results that the gate is moving to a mechanical end-stop, the motor tork is buzzing and i switch off the power from the gate drive.
back ground info:
- The gate was functional, i added a code panel for opening, this had been functional and still is. (when the code is correctly pressed the gate starts opening)
- then i discovered above strange behavior of the gate drive (Not closing, but opening further then the end stop)
- i disconnected the code panel. this did not have any effect, (sadly)
- i verified the functioning of the photo's, 2 pair have been installed, NC contact and they are functioning correctly.
For now i am stuck how to resolve the issue.
could this be a problem with the board itself, replacement of the 740D circuit board needed ?
looking forward to advise from the community
Thanks in advance
Best regards
Emiel
(26-08-2025, 03:13 AM)emiel Wrote: I have a sliding gate with a FAAC 740D control board.
back ground info:
Thanks in advance
Best regards
Emiel
Hi Emiel,
It could be that the photocells are not able to see each other I would check if when the photocells are obstructed you can hear the relay click on the board, alternatively it could be that the gate is getting a constant open command possibly from the keypad you have wired in, to test this check to see if you get continuity across the relay on the keypad to check for a stuck relay. I would also check your cables going out to the keypad to see if there is a short.
Have you got any other accessories wired into open?
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 2 3,774 01-10-2025, 09:17 PM
Last Post: Adam_k
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 3,620 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 3,387 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,432 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 2,945 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 8,518 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 6,558 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 7,353 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 6,168 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 11,577 21-11-2022, 09:54 AM
