  • 27 Vote(s) - 3 Average
FAAC problem
I have a newer FAAC control box, and using 400 series 220v actuators. when i activate the dual gates, they both open about 20% and then they close and the motors keep running. I do not have any safety features, no photo sensors , no other options or accessorizes .
I have tried the learning process and nothing seems to correct this. There is no binding or obstructions on the gates, i even unhooked them and tried to run the actuators unattached.
I hooked up the actuators to my test bench switch and they both work perfectly.
they are set at maximum torque. any suggestions?
  FAAC 455D - wiring issues? jonah 6 2,118 20-02-2026, 06:30 PM
Last Post: jonah
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 8,797 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 7,567 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,996 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 5,185 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 4,428 18-11-2024, 11:48 AM
Last Post: robhight
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 11,158 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 8,292 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 8,669 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 7,302 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
